Old 05-21-2014, 05:02 PM   #6
epapp
epapp's Avatar
When it gets to the end of the '0' is when the fans turn on, ~210F-~212F according to my obd2 temp readout.
Your water pump may be in the process of failing, and can still circulate water, just not as effectively as a new pump. The fans are most likely able to pick up the WPs slack, which is why the temp gauge would get up to 0, but not go any higher.
epapp is offline   Reply With Quote
