Old 05-20-2014, 06:42 PM   #11
healthservices
Registered Boxster abuser
healthservices's Avatar
Originally Posted by aneal000 View Post
Spring is broke and appears to be keeping the valve from closing. I'm not saying the valve is not bent, but I don't see how it could happen. I'm going to replace the spring - because I'm this far into it and it seems silly to not try. I'll then do another leak down test before I put it all back together. If it fails that test then the head comes off. Is that a fair line of thinking?
If the valve is good you can do a leak down now with the cams out and the spring off of the valve. if it does not seal valve is bent.
