Old 05-20-2014, 05:34 PM   #11
healthservices
Registered Boxster abuser
healthservices's Avatar
Originally Posted by aneal000 View Post
It just seems like the leak down test confirmed what I already knew. Not sure what else it is telling me? Thanks again for everyone's input.
Now ask yourself this question. If air from the leak down test will not hold the valve closed. it tells you something...
The valve is bent.
If the valve was not bent the valves would seal and not leak when the cam has released the pressure off of the valves.
