Old 05-20-2014, 04:22 PM   #11
Ian c
Originally Posted by aneal000 View Post
If this is the case how can a leak down test be used accurately if it forces the valves shut? .
With an air leak test you are basically pressurizing the combustion chamber to perform a pressure test to see what is NOT sealing .
A bit like ressurizing your water pipe system at home to find/check for a leak .
We knew you had a leak , the compression test told us that .
What the air leak (leak-down) test tells you where it is leaking from .
The inlet and exhaust valves and the piston give you a "closed space "
Air will either leak by the piston (bottom end problem) or the head (top end problem) or the gasket (head gasket problem)
You've now found where its coming from ....
Ian c is offline   Reply With Quote
