Old 05-20-2014, 08:51 AM   #4
Gelbster
At every cold start your factory filter is bypassing oil straight to the main and rod bearings.
See how much of the material is ferrous and let's go from there.
In my rod bearing event , there was copper/gold debris in the pan and the LN spin-on filter.There were two larger pieces on the oil pickup screen. Next place to investigate will be the oil pump and scavange pumps.
Interesting was a large (almost a teaspoon size)soft lump of black sludge (Moly powder?) on the LN magnetic drain plug. I am wondering if that blocked the oil gallery/feed to the rod bearing. Only a complete teardown ,clean and inspection will tell.
I am determined to find the cause of the problem instead of just muttering about P cars. I'll post photos of what I find so it adds to the fund of knowledge on the Forum.
