I have a similar issue.What saved me from even more damage was Jake Raby's spin on filter upgrade.
Suggest you look in your OEM(?) filter also.Sadly the experts say the OEM filter does not filter 100% so you may need to totally dismantle the entire engine to remove ay debris magnetic or otherwise. Let's hope that isn't required because as someone doing that job right now can tell you it is a major $&time effort.
