Old 05-16-2014, 03:38 PM   #1
BYprodriver
BYprodriver's Avatar
Anytime engine damage is suspected the oil filter should be removed & inspected for metal etc. It is made from paper so cut the ends off & spread the filter open so you can inspect it for foreign debris. Drag a magnet thru any particles you find to see if they are iron based metal. The filter housing is like a screw-on cup that holds about 3/4quart of oil so be prepared to contain the oil.
Go Cardinals!
