Thread: ECU recoding
Old 05-13-2014, 01:28 PM   #6
Xcellr8
Originally Posted by ECU Doctors View Post
...Does your Boxster have a complete Immobilizer and ECU Set with at least 1 Remote?...I'll be able to explain to you what you will need to get the car running.
Thanks for joining in on this conversation. Several of us probably have questions about this topic.
For example, original poster did not answer if he had the complete set. However, I do, BUT, isn't there always a BUT? My set was pulled from a running 2002 S 3.2L that was wrecked. I'd like to use the set in a 2001 base 2.7L. My understanding is that the DME (CPU) will need to be reflashed to work with the 2.7L. Correct? It is also my understanding that one would need the PST2 or PIWIS to do the reflash. Is that also your understanding? I thought I read somewhere that there was a third part source for equipment that could reflash a DME. OR... from your user name, it appears that you might also do this kind of work.
What can you say to these questions?
Thanks,
Joe
Xcellr8 is offline   Reply With Quote
