Old 05-12-2014, 08:34 PM   #3
DG Boxster
horn woes, and wrong fuses?
I'm also a noob and having horn difficulties. No horn working at all.
I found the fuses, and the piece of paper says there should be a 25 Amp (!) fuse in B2, which is the horn (98 Boxster). Seems like a lot.
Sure enough, there was a blown out 5A fuse there. For a quick test I put in a 10A fuse and the horns blow continuously
Can anyone tell me which relay is the horn relay?
What book should I buy that would have this info - the Bentley book?
Finally, and most disturbingly, lots of fuses didn't seem to match what is in the fuse chart. Like maybe 1/3 of them are wrong, and usually higher than what is supposed to be in there.
I could be wrong, but I don't think so since B2 was the horn fuse... I'm pretty sure I'm reading the chart right.
DG Boxster is offline   Reply With Quote
