Old 05-11-2014, 08:23 PM   #1
Mike_Yi
Originally Posted by oc-boxster View Post
Who makes a fiberglass hardtop?
I can't double-check because I'm not home right now, so I don't have access to the pictures I took, but when I took the top apart to get it painted, I'm pretty sure it had a Porsche part number molded into the underside of the top. It could be aluminum, but I didn't scratch it to find out because if it was fiberglass, I didn't want to weaken the structure. I can tell you that without any of the headliner and trim, this top is really light. IIRC, it was as light as some of the Boxster Spec guys were saying the fiberglass tops were. Did any aftermarket manufacturers make fiberglass tops with the ears?
But again, I can't be sure about any of it as I'm out of town. When I get back, I'll check the pictures to see if I remember correctly.
Does anybody know of a way to test if the top is fiberglass or aluminum without damaging it?
Mike_Yi is offline   Reply With Quote
