Old 05-11-2014, 12:17 PM   #6
TopChuckie
Was it outside during the bad weather?
Either way, check for moisture under the drivers seat.
Also check the battery with a volt meter at the battery posts, then check voltage at the post clamps.
Corrosion between the clamps and posts can keep a battery from charging.
Low voltage or a corroded battery clamp can cause weird electronic issues.
No, in the garage the whole time. No moisture. No corrosion whatsoever on the clamps, squeaky clean.
TopChuckie is offline   Reply With Quote
