Old 05-09-2014, 12:36 PM   #9
Gilles
You can line the cams up using the notches, but be aware they are not symmetrical (centered):
Jeff,
Thank you much for the picture, I will ensure that the cams are aligned the same way as the picture, 2-6 bank center picture (Cayman driver side) and the 1-3 bank right picture (passenger side)
NOTE: The Smaller 1/2 moons are facing towards the outside of the engine, right?
Once I align the cams I will lock the crank, then the cams and I can move on and remove the chain tensioners and lastly the IMS cover..
Getting there... Thank you for the support!
Gilles is offline   Reply With Quote
