Old 05-06-2014, 06:42 AM   #1
Coaster
Coaster's Avatar
I gingerly tested it for opening and closing this morn. Using both the inside handle and the outside it drops, but not as quite as far as before. It just barely hits the roof when you open the door. It goes back up to the not quite closed position when the door is closed, I did not try the window switch or opening the top.
Looks like parts run from $170 for generic to $270 for “OEM”. I found one OEM for $240 but not sure if it’s used yet or not.
The PO replaced the passenger motor so I was hoping I would only have to replace the regulator but I can’t find the regulator by itself
Off to search DIY threads for this replacement.
Coaster is online now   Reply With Quote
