Old 05-03-2014, 10:41 AM   #3
runjmc2
Of course check the simple things, e.g. pressure test cap, fans, leaks in coolant tank, etc....but the thump is of concern and you may want to consider the possibility of a water pump failure. If that is the case, running it may not be a good idea. I assume you already checked for water in the oil and oil in the water...
runjmc2 is offline   Reply With Quote
