Old 03-09-2006, 02:57 PM   #1
bmussatti
Guest
Posts: n/a
Here are the steps to replace the ignition switch, this should help you:
"What you will have to do on either a Boxster or 996 is to remove the instrument cluster first. This is done by removing the two screws that are behind the hazard switch and the microphone cover to the left. Once the cluster is removed and unplugged, set it aside. Now at this point you will find two screws that are on top of this lower section holding it in place. Remove both of the screws and then pop the piece away from its lower securing pins and then fully remove. The lower pins are part of this piece and it allows the bottom of it to snap into the dash. After this is removed you will see the bolt that holds the lock assemble in place, remove this bolt. The left side vent assemble also has to be removed. This is required so that you can access and remove a screw on this side. The next step is to remove the actual key tumblers. To do this rotate the key to position 1 and insert a paper clip that has been stretched out into the hole firmly. Now pull the key assembly with the paperclip out as one unit. Unplug all electrical connections and remove the lock assemble.
Scott Slauson - PCA WebSite - 8/10/2005"
