Old 03-07-2006, 03:22 PM   #1
MNBoxster
Hi,
As Bruce says, there can be many causes. But, if it's small, it's probably nothing to worry about immediately.
Get under the Car and check it out. Check Cam Covers, Oil Cooler Lines and RMS (usually leaks right in the Center) if this is what you find, RMS is usually a Progressive Failure, so you can keep a watchful eye on it.
Also, could be Gearbox, Clutch Hydraulics so check these too. Hope this helps...
Happy Motoring!... Jim'99
