Old 04-14-2014, 01:28 PM   #34
Perfectlap
Perfectlap's Avatar
The Spin On filter adaptor omits the factory bypass that diverts bypass oil around the filter at start up and at times of higher than normal oil pressure. During these periods the factory filter does not filter 100% of the oil. Tis is also even more true if the factory bypass spring has lost tension due to high oil temps or time in service.
Does this mean that using a factory filter will have a marginal increase in engine wear over the WIX type?
p.s.
Would the IMS Guardian be of value in this situation? One where you already have debris in they system however fine.
BORN: March 2000 - FINLAND
