Old 04-13-2014, 06:16 PM   #15
pmitchell
Hello all.. I am having a similar problem. My top is stuck up. All indications seem normal. Parking brake light, windows drop when center latch is released. But no motor sound at all.
I have a '99 Boxster. At first the problem was intermittent. Now, no workie at all.
I know electronics. I want to troubleshoot as much as possible from the top control relay/module.
So... Question for Maurice...
Do you have a document that shows the pin-outs for the relay? And what indications(ground, battery, etc.) would be seen at each pin (and at what state the top is in)?
I do have a wiring diagram that shows the relay and what is connected to it. But, it is not really clear as to what should be read from a multimeter on those pins.
Again, I can probably figure it all out... But, if you have already done this, it would be very helpful....
Thanks,
Phil
pmitchell is offline   Reply With Quote
