Old 04-13-2014, 12:30 PM   #22
kcpaz
I'm confused as to why you think you will need more than a 285mm wide rear tire (which is easily fit without going wide body in the rear)? If you are worried about straight line traction, install an LSD. Installing a "bigger wing" isn't going to do anything for traction unless you are going at speed around a race track. If you just want wide body because you like the way it looks then I can't fault you for that, but don't try and justify if as a performance modification on a street car. This is coming from somebody who daily drives a Boxster with 370whp, with an LSD, on 275mm rear tires (NT05's) and I only have mild traction issues in first gear. Also, is your car a 6speed car? If not, traction loss might go a long way to preserving the weak 5 speed transaxle.
kcpaz is offline   Reply With Quote
