Old 04-08-2014, 08:29 AM   #1
cas951
Originally Posted by kindlethespirit View Post
Thank you. They just did the oil change a few hundred miles ago and put in 9.5 quarts, so not sure what is going on.
I think 9.5 qts is a little too much. I would suggest you drain some. Check your manual to see what your capacity is. Overfilled oil causes AOS failures.
2008 Boxster S PDE2
02 Boxster S Blk on Blk(Stock for the Wife)
88 turbo S (My Toy) slightly modified
cas951 is offline   Reply With Quote
