Old 04-05-2014, 06:09 PM   #16
Jager
Jager's Avatar
Originally Posted by Benjamin View Post
Yep, that worked. It was torqued quite a bit, or maybe it just seemed that way because I was using a wrench instead of an 18 inch breaker bar. The trans and clutch are now off and I'm about to research methods of locking the flywheel for bolt removal. I also found that I only have one guide sleeve, so I need to see how many are missing and make another parts order.
Thanks for the help, everyone!
Locking the flywheel? Get yourself a 6" piece of steel bar and drill a small hole at one end (large enough to go over one of the pins on the flywheel) and another hole at the other end (large enough to insert one of the transmission bolts through it). Use one of the transmission bolts to anchor the bar (make sure it is threaded well into the motor) and slide the other end of the bar over one of the pins on the flywheel.
Jäger
300K Mile Club
