Old 04-03-2014, 09:30 AM   #5
JayG
On the slippery slope
JayG's Avatar
check the switch.
I had a similar problem. All the lights except for the head lights worked, even the high beams worked.
I pulled the switch (takes about 10 min tops) and sprayed it with electrical contact cleaner. Spray the cleaner into the shaft and work the switch in all positions.
That did the trick for me. It may be a temporary fix and probably will need to replace the switch at some point. The run around $125 online
There are DIY links around that show you how to remove the switch
2004 996 Targa Tip
Instructor - San Diego region
