Old 03-31-2014, 10:37 AM   #15
DennisAN
DennisAN's Avatar
Originally Posted by healthservices View Post
Yes like a pcv but because the motor is a flat 6 it has a harder time controlling the oil vapors. Its also different from a pcv in that the porsche uses a close crankcase system with no vent.
In that case...what does Subaru do? They're the only other flat boxer motors being built today IIUC.
Other cars I've worked on have two vents. One is the PCV valve connecting the crankcase to the intake manifold on the engine side of the throttle plate. The other is a plain tube vent (perhaps with a flow restrictor) connecting the crankcase to the intake plumbing between the MAF sensor and the throttle plate. Is the AOS a combination of these two functions?
Base 2000 986, beater 1996 Miata, 2011 Suzuki SX4 AWD
Feline mechanics Condoleezza and Dukie
DennisAN is offline   Reply With Quote
