Old 03-25-2014, 06:38 PM   #17
jc986
jc986's Avatar
Originally Posted by kiyakubuke View Post
are you referring to a new emblem or are you saying that the adhesive currently on the emblem will be reusable after I take it off and paint it?
Kiy,
New emblems come with adhesive already on the back, with a peel-away backing. Just make sure your new emblem is centered before you peel off the backing to attach, AND make sure the car surface is clean. If you use your old emblem instead of a new one, you will need to add emblem adhesive to it to reattach. For mine I used emblem adhesive that I bought at AutoZone.
When I did mine I wiped the car surface down with rubbing alcohol and paper towels to remove dirt and oils. And I aligned everything using masking tape to make sure my lines were straight.
Here's a HINT: to help you with centering, raise your rear spoiler manually (using the button on the drivers side kick panel) - when it's up you will see there is a bolt that holds it in place, which is directly centered to the back of your car. Use that as your frame of reference for centering and it will line up perfectly.
97 Boxster 2.5L
07 Mercedes C230 Sport
jc986 is offline   Reply With Quote
