Old 03-21-2014, 07:30 PM   #17
vthakka
What I am assuming is that you think ims is mandatory. Rather it is not so much optional but preventative, this means arguably it has to be done. But not as soon as you buy the car. Monitor oil filters at frequent oil changes for metal shavings. If you find any you need a bearing, if the car needs a clutch, might as well go for a bearing. If the car is running fine and you are putting the right oil in the car and changing it around every 3 to 5k miles you are fine. More info is the 1997 to "2001.?" Cars have a less likely to fail bearing, while later 01 to 2009 cars are more likely. The benefit of a 2000 is a bigger engine and of an 03 is a glass top and new lights. Some find the 2.5 slow others find it the most like a classic light weight low HP fun porsche. Suggestion is look for a 98 99 or 2000 with less than 85k miles and has been well cared for. Also ask if the cars water pump has been replaced because it is very likely to fail from 70k to 100k.
Thanks BIGJake I just got off the phone from the seller he sent me some pic of the PPI Please let me know whats your take on it
vthakka is offline   Reply With Quote
