Originally Posted by notech
I have a BE-6600 MOST Ampli, CDC and CDR23. No bose system.
I will try to find a pinout and connect speakers directly from it's output.
Last question, how do I run cables from trunk to cabin?
If you go in the Frunk (Front Trunk) remove the battery cover & battery (make note of the pos & neg so you put back the correct way round) , then on yours (left hand drive?) on the right hand of the firewall you should see a large rubber grommet, use a stanley knife to slice an X in it & pass the wires through & push them down for about 6 inches.
They should come though above the accelerator peddle & you should be able to feel them
Dan
