Old 03-11-2014, 10:03 AM   #10
TerryT
2002 Boxster
Originally Posted by dagdisco03 View Post
There are 3 micro switches. Inside door handle, Outside door handle and the door latch assembly. Each does it's own thing. Pull inside handle window should go down 1/2 inch. Release handle window should stay down. If you let go of the handle and the window goes up it's the micro switch in the latch assembly.
Same for the outside if you are pulling the handle on the outside and the window does not go down it's the outside handle. If it goes down and back up with the release of the handle it's the latch that has the issue.
I don't think there is timing involved. If I open a door the window stays down forever until I close the door.
Hi, what is it then if the window just doesn't go up once you close the door, it just stays down ?
Is it the latch ?
Terry
TerryT is offline   Reply With Quote
