Old 03-08-2014, 10:07 AM   #3
Bmod986
Bmod986's Avatar
Originally Posted by nieuwhzn View Post
Just to make sure, check if the oil is not coming from the AOS area and dripping down around/through the transmission.
Thanks for the info I will take a closer look but the oil is all on the engine side not on the trans. But if it is the air oil sep then that could save me a couple of dollars until I have enough to do the ims along with the clutch and flywheel. Upgrade everything later on. I just don't want to put down my resources on the car at the moment.
Any way I will keep you guys posted.
Bmod986 is offline   Reply With Quote
