Old 03-06-2014, 11:32 AM   #1
thstone
  • Check all front suspension components, mounts, and bushings, including steering rack.
  • Spend $45 and install GT-3 brake ducts for better front brake cooling.
  • Check wheel bearings.
  • Check tires for excessive wear especailly on inside portion of the tire. This is often missed when inspecting tires on the car because the wear is not easily visible.
  • Check the front underbody panels to be sure that they are firmly mounted to the car and not flapping in the wind.
