Old 03-05-2014, 06:30 PM   #4
986_inquiry
2006 987
986_inquiry's Avatar
Originally Posted by keithl View Post
Thanks!
It actually does come on with the other lights. Will there be codes there even if the CEL isn't on? Does it sound like a flakey fuel pump if the CEL isn't coming on?
Was this resolved? I'm having a very similar issue with a 987.
I will shift (downshift or upshift, doesn't matter), and once in the new gear the car acts like the gas pedal isn't even connected. Like tonight at a green light I had it in first and it started moving then it acted like the gas pedal wasn't even connected, so I shifted to 2nd and it acted normal again. Seems shifting fixes it, but I don't want to always have to shift, it should have power in the gear I'm in. Happened in 5th too, I even floored it and pumped the peddle, just acted like the gas pedal was connected to nothing but I could hear the peddle hit the floor, but as soon as I shifted to 4th it behaved normal again.
2006 987 2.7 manual silver/black, PASM, OEM drilled rotors, heated seats
1998 986 2.5 manual black/tan with bad engine = SOLD
986_inquiry is offline   Reply With Quote
