Old 02-25-2014, 03:03 PM   #6
Steve Tinker
Steve Tinker's Avatar
Ran.....
This is what you can do with your ROW spec car - the same as what I have done here in Australia.
1) Replace the original exhaust manifold (headers) with something like Deluboz Parts (Top Speed Auto) sell in the US - strait swap with small HP gain higher up the rev range and a slightly harder sound.
2) Replace the cats with delete pipe from same supplier. This is illegal if cats are required in NZ. You will need to weld in stubs (supplied by Deluboz) into delete pipes to screw in O2 sensors which normally screw into the cats. I just got the local welding shop to do this - less than an hour - cost $60-00. Definate HP increase and much better sound above 3,500rpm.
I retained rear silencer (muffler) to control drone.
Che @ Deluboz ships to this side of the pond and I have had no problem with my system in 3 years of it being on the car.
Hope this helps.
2001 MV Agusta F4.
