Old 02-24-2014, 01:34 AM   #2
Steve Tinker
Steve Tinker's Avatar
There are a couple of parts you will require:
1) Shock upper support mounts (front) x 2. The rubber inserts wear and can knock.
2) Shock upper support bearings (front) x 2. These bearings allow the strut to turn & can rust.
3) You make no mention of new bolts and nuts - its very advisable to replace all used hardware on a suspension upgrade.
4) Item 6 on list - control arm link, you will need 2.
5) I see no mention of the front & rear Control Arms (coffin arms) x 4 - but maybe our descriptions in Australia and the UK are different to the US.
I would suggest you go through the PET diagrammes and double check your parts requirements before ordering.
2001 MV Agusta F4.
