Old 02-23-2014, 07:01 PM   #15
Jamesp
Beginner
Jamesp's Avatar
The problem with using blocks on this car is the limited area of the hard points. You dont have a frame to put a block under so you need to pick up just the jacking pad with the jackstand. I did not try to jack up on the lower rocker panels but they look soft and I think there is a very high likelyhood they would crush if used for a lift or support point.
2003 S manual
