Old 02-23-2014, 09:56 AM   #1
uladzislau
Originally Posted by clickman View Post
Interesting. Your oil filler tube middle section has metal? braiding on it. Mine doesn't. Did you put that on yourself?
When I replaced my coolant tank recently I replace the oil filler tube, and the part number you list is what I got and no problem with fitting.
This is a spling clamp which holds two tubes together, the tube itself is 100% plastic of cause. I've reused the factory one at first but now I've put screw style clamp instead there. And yes, I've put everything together myself.
uladzislau is offline   Reply With Quote
