Old 02-18-2014, 06:18 AM   #1
tuanle16
so, what i noticed is that the nipple is connected to the pump which in turn is connected to the tank. the nipple and pump are one unit. the pump seems to "rotate" in the hole/connection of the tank. this is where i am noticing the source of the leak. so, perhaps there is a gasket or washer there that needs to be replaced...??? but i can't seem to remove the tank for examination without fear of ripping the tank out and causing a bigger issue. hmmm...i guess if there is a leak..i might as well replace the tank anyways. thanks.
-Tuan
tuanle16@juno.com
tuanle16 is offline   Reply With Quote
