Old 02-16-2014, 07:47 PM   #1
tuanle16
windshield washer fluid reservoir
so i did a search on this site and renntech, but am still having trouble. there is a leak on my windshield fluid reservoir. most people say that the tubing just came loose, but mine is definitely not. i have removed the tire and wheelwell cover. i accessed the container and noted that the leak is coming from the general area of where the tube goes into the container. i removed the tube to ensure that it wasn't cracked or worn. it visibly looks good. i tried placing it back on with a zip tie to tighten it. it still leaked. funny thing was that the nipple and plastic part that it connects to is very mobile. it doesn't seem "loose", but it does rotate. is that normal? anyhow, i figured that was my problem area. i couldn't see directly at it though. i tried to remove the tank, but was unsuccessful. anyone know how? i gave up and ultimately, just applied silicone sealant to it and now am crossing my fingers that it will stick. will the head of the engine/brakes cause it to melt with time? i am going to allow it to dry overnight before trying to fill the tank again. but if this doesn't work...i'll take any suggestions. thanks guys.
-Tuan
tuanle16@juno.com
tuanle16 is offline   Reply With Quote
