Old 02-16-2014, 06:17 PM   #10
rick3000
There Is No Substitute.
rick3000's Avatar
I'm definitely not an expert on the subject, but when I had this problem with a home audio system, it was the result of an impedance mismatch. The impedance of my speakers did not match that of my amp, and I needed excessive power to achieve a reasonable volume level.
Just a thought; as I stated, I'm no expert.
My optimum volume level on a CDR220 with a stock system is between 10-15.
TO
TO, you nailed it. My iPod connector has a Hi/Lo filter switch, and at some point during the amplifier installation it got switched off. I didn't even now it had a switch until I pulled everything out again to see what the problem could be. I taped the switch to make sure it doesn't happen again.
Thanks for all the replies!
