Old 02-15-2014, 07:16 PM   #11
rick3000
There Is No Substitute.
rick3000's Avatar
Jake, I want to thank you for replying and clarifying everything. I should add that I think you offer a great product, that it provides a solution to a problem that could not previously be solved and gives a lot of people piece of mind. If I had a single row IMS I would likely buy your retrofit when I changed my clutch. I have a lot of respect for you for creating a solution.
@VWAudiChris - That post is my opinion, which is that, yes IMS failure can happen, but it is not as likely as the number of posts about it would have you believe. Almost every potential or new Boxster owner that comes to this site posts about it.
There where about 165,000 986 Boxster's ever sold, there is no solid statistic on how many suffered IMS failures. So any number is pure speculation, the average guess is between 1-8%. It's up to you to decide how worried about it you want to be, and if you are worried Jake has provided you with a solution. If you aren't then you can start enjoying your Boxster that much sooner!
EDIT:
Well worth a read:
We responded to a DEMAND and solved a problem. ALL I care about is solving problems, its all I know how to do. Read this PCA article about me and my shop that was published in December of 2013. See page 11 of this PDF for a better understanding as the interview reveals quite a bit thats never been mentioned before.
http://www.peachstatepca.org/content/newsletters/PresseFall2013.pdf
