Old 02-15-2014, 03:57 AM   #1
BTfd2e93
ok .. ive decided to start planning for my suspension overhaul project.
Thinking about the list of things I need to buy ....according to the boxster 101 project book - these are items needed. Anything else you can think of?
- Control Arm Links (Front & Rear)
- Tie Rods (Inner & Outer)
- Tie Rod Boots
- Sway Bar Droplinks (Front & Rear)
- Sway Bar Bushings (Front & Rear)
- for the struts, im going to use Bilstein dampers ... & retain my stock springs as the height and spring rates are pretty good now.
BTfd2e93 is offline   Reply With Quote
