Old 02-13-2014, 09:41 PM   #11
BTfd2e93
2001 and 70K kms
im thinking ... i'll probably do a refresh with the suspension components (except the springs probably, im quite happy with the height and spring rate) ... and be done with it.
the cars handling is a bit wiggly over bumps ... so i suspect all the items you mentioned below have probably aged.
There are only lower control arms on the Boxsters.
The control arms are expensive relative to other suspension components.
What's the year/mileage of your car?
You might want to check out your drop links and sway bar bushings first, as new drop links are about $50 each and bushings are cheap.
Rebuilt track arms available for $150/ea from another vendor. Worn track arms make noise over small imperfections in the road or parking lot and are most annoying at low speeds.
Clunking can be a result of a worn strut bearing or mount. The bearing is about $50/side but you have to remove the entire strut assembly to replace, hence it may be time to replace the strut as well (~$250each).
Suspension stuff gets expensive fast!
BTfd2e93 is offline   Reply With Quote
