1. "IF," and I know that it is a big IF, the oil line from the filter to the plain bearing should be severed, what would be the result?
Trust that ANY event that would lead to this would create serious damage otherwise and you'd probably not have an engine left. The oil line is tucked tightly against the bottom of the engine and is far from the lowest point. That said, I am building a C4 996 into a Rally car just to prove that this line and position will take the most harsh off road environments possible, with no additional protection over whats offered in stock form.
What would be the result if the line did fail? Well, you'd take advantage of the fail safe designed into the arrangement. We have forced these failures and know what happens, and the result has not been total engine loss to date when we did these tests.
Would you know soon enough from the oil pressure gauge in the car (would it drop instantly to 0?)
It does not drop to zero, as the volume loss from the hose is not significant enough to create a total loss of OP. You will lose 1-1.5 bar of pressure and unless the engine is ran out of oil the rest of the engine does not suffer from this event. I know because I have done this purposely.
to swiftly turn off the engine or would that not work since you are taking a small amount of oil from the filter adapter and the pressure would not be affected?
If you are quick on the draw you can shut it down and be fine. For those worried about this we have designed an auxiliary oil pressure indicator light that installs with a pressure switch in the line and can be used to indicate a loss of OP to the IMS Solution. We have never sold a kit, because its never been an issue with a buyer. I used this arrangement during testing to feed OP values to my data logger as live pressure that the IMS Solution was seeing.
Is there any application where the Double Row Pro could be a better choice?
I developed both of them, and the only benefit that the Single Row Pro has is reduced cost. This is the only reason we released the Single Row Pro, to be a stronger arrangement than the Classic Single Row, but have a mid price point.
2. Once you go IMS Solution, can you ever go back to a bearing? (not sure you would ever want to do that)...
Absolutely you can! In fact we did this during testing when evaluating an OEM single row, Classic Single Row, Single Row Pro and IMS Solution against each other from a MPG, BSFC and HP/ TQ point of view, all back to back and all in the same engine. We installed three of the technologies in a single day, back to back to back and the results were so unbelievable that I'd dare not post them, else people would think that we were making it all up.
My Faultless Tool installs and extracts all IMSB technologies that we have developed to date. No worries.
