Old 02-10-2014, 02:41 PM   #288
Edreamsz
Hubert, you certainly can however not recommended. If you go ahead think about surgically clean microfiber cloth when doing so. There are no scratch (& UV) protective film on the inside part of the lens therefore any hard-dust on your cloth will make it worst (scratch the lens).
Polishing (finishing) will need to be done using a "camera lens polishing cloth'. Doable but again, got to be done in a very clean environment.
Thanks for the tip,,,The dreaded happened to me,,I thought that the headlights where adjusted properly. This was sadly not the case (by a very small margin!)
The projector scratched the inner lens!
So, I am looking to see if somebody that is an expert in headlight restoration can remove the scratches. The scratches are fairly deep and won't just buf out with scratchX.
Edreamsz is offline   Reply With Quote
