Old 02-10-2014, 03:12 PM   #1
Jamesp
Beginner
Jamesp's Avatar
Originally Posted by Walter White View Post
James, could you make a recommendation on the magnets. Do you like the size and shape magnet you are using. Where do you get them? Thanks
I get them from a store named EPO or Electronic Parts Outlet in an area south of Houston called Clear Lake. They are likely cheaper on line. I typically buy 1 cm diameter or smaller. They are very strong. They have to be slid and peeled apart, there's no way to just pull them apart. The 1 cm are very strong so I chose them to install on the outside of the oil filter housing with electrical tape.
2003 S manual
