Old 02-04-2014, 11:04 AM   #2
recycledsixtie
recycledsixtie
recycledsixtie's Avatar
That tool is a very bad idea, you will crack the reusable plastic housing. This is what you need:
+1 on this. You can get it from Pelican Parts. Careful you don't overtorque the plastic filter housing when you put it back on. Also note the position of the rubber/plastic o ring when you take the filter housing off. Last time I did it I put the o ring at the very top - not the correct position and after retightening it it got squeezed and lost enough oil to show on the driveway when I was driving away.
Careful also about using the correct torque when tightening the drain plug. If you don't have Wayne Dempsey's 101 Projects for your Porsche Boxster, you should get it and it is cheap at $30. First oil change is messy, 2nd not much and the 3rd I expect perfection from myself.
Cheers, Guy
