Originally Posted by That said, if you already have material laden oil, the IMS Retrofit procedure changes, else the replacement bearing, and the rest of the engine could become compromised at a later date.
See this link.
[url=http://imsretrofit.com/bearing-already-failing/
Bearing already failing?[/url]
Jake is making a good point here. I would look into what it takes to get all of the flakes out of the oil, and consider a sealed bearing from Pelican or a sealed ceramic.
