Old 02-01-2014, 08:50 PM   #1
John Bergen
Boxster S Bassist
Unhappy IMSB: what else should be done at same time?
Took my 2000 S in for an oil change and found the dreaded metallic fragments in the oil filter, thankfully before the bearing self destructed. Will have the LN Engineering ceramic bearing installed. In addition to clutch replacement (car has 74K miles) what else should be done at same time? I assume throw out bearing, how about the throw out bearing guide tube? How about transmission mounts? Rear main seal? (Is this the same as the "transmission seal"?) Anything else? Thanks!
John Bergen is offline   Reply With Quote
