Old 02-22-2006, 01:22 AM   #5
blinkwatt
Send a message via AIM to blinkwatt
Originally Posted by vietoriouz
I had both CEL for 1128 and 1130 after filling up; possibly having bad fuel at the local Chevron or due to a Octane Booster. After reading many threads, it seemed the problem might lay somewhere else. I tried cleaning the MAF and the throttle body, checking for vacuum leaks with little improvement. I ultimately replaced the MAF, erased the codes and the engine runs better. However I am currently experiencing a idle problem. It goes from 700 to 800 with the ac off and at idle. I thought I might just be paranoid but then the revving effect started happening when stepping on my clutch at low speeds. The revving occurs after every 2 - 3 stops. Now I am freaked out . I am in 1st and I am slowing down to a stop and disengage the clutch and the car revs to 1500 rpm. Help Please. Can it be due to my o2 sensors?
How many miles are on your car? And what year is it?
-99' Zenith Blue 5-spd...didn't agree with a center divider on the freeway
-01' S Orient Red Metallic 6-spd...money pit...sold to buy a house
blinkwatt is offline   Reply With Quote
