Why did I clean my engine?
Another quick update:
I've received most of the seals this weekend and have already narrowed them down to two contenders. This weekend I'll use them both and decide which one is better.
I've also received the mounting hardware with silver and black chrome caps, BUT... Thanks to Jaykay's comment I now know what the OEM fasteners are called. As a result, I've decided to scrap the original hardware and find a set of Dzus fasteners that will allow for cover swapping without a need to change mounting clips.
On the side, I've been working on the LED strips for the covers and finding a reasonably priced source for them. Tracking down the female connector that plugs into the car's defroster harness has been a ************************. I've found someone in the UK that stocks it, but they have a minimum order quantity of 200. I'll probably bite the bullet on this one and go ahead with the order.
Lastly, I've received my first batch of quarter inch plexiglass for forming. I am also experimenting with half inch plexiglass for additional sound deadening, heat resistance, and strength. The only issue with the larger plastic is that it is double the price... And forming it is a complete PITA.
I expect sometime early to mid February I should have the first couple of covers done and the rest shortly after.
Of course, I want to say thank you to everyone for the kind words and continuing support!
If you are interested in a Comfort-Top module, please visit:
https://www.enhancedautomods.com/shop/comfort-top
