Old 01-29-2014, 06:43 AM   #11
993innc
993innc's Avatar
I can't see any significant difference between shimmed or threaded types of LCA's. Shims come in varying thickness and often require more than one to achieve the desired camber. Also, the shims are somewhat expensive and can be easily lost in a tool box. It is hard to tell but I wonder if the threaded type might be vulnerable to dirt/muck getting onto the exposed portion of the thread and might be hard to adjust after a few years. Pick your poison.
Yes, lower the car and you'll need new adj rear toe links. Most folks do not use rear adj LCA's.
I agree with you about the trash getting into threads. But A) I hope not to mow the grass with the car B) those joints can't be any more susceptible than tie rods etc...
Could always wrap with tape to keep clean.
You've been a big help, thank so much. Now I just need to figure out who to buy from. As usual, spending waaaay more than I want to. Hate that I have the need to go fast
Chris
- 1997 993 (started it all) - 1975 914 1.8L w/F.I. (restoring now) - 1985 "1958" 356 Speedster (cruiser until 914 is complete)- 2002 Boxster (future, ney...current! track car)
RENT ME FOR YOUR NEXT VACATION: www.vrbo.com/489534 or www.vrbo.com/499924
993innc is offline   Reply With Quote
