Old 01-29-2014, 03:55 AM   #6
kjc2050
kjc2050's Avatar
Originally Posted by fullthrottle52 View Post
I did a search and found quite a bit on replacing the ignition electrical switch, but not on replacing the whole ignition (part that looks like a gun). Lately when I go to start the car the ignition is pretty stiff to turn. It always starts but needs more pressure than normal. Is this the ignition shaft or the electrical part that needs replacing? Is there anything I can do to "fix" this issue or should I simply replace the gun and electrical switch.
Thanks for any thoughts.
Sounds like the electrical portion. Mine became hard to turn, then a little notchy, and then went south altogether. Replace it now.
